JL W6W12 Questions
Username: Fordexped
Ive been looking to upgrade my sub system for a while to something considerably louder and hopefully cleaner and have been looking mainly at JLs. I recently found W6W12s on sale on sonicelectronix for like $400. From what I read these are the subs I'm looking for but I still have a few questions. Right now I'm running a 15" Eclipse titanium in a ported box on a Hifonics Zeus 1200 watt amplifier in a 2001 Expedition. Would 2 W6s be louder than this? Will the amp I have work for two of these subs? Also would I be better off going for 1 W7? Lastly, would it be necessary to make improvements to the wiring setup I have or the alternator or do any other sorta major additions to my system. The sale is ending pretty soon so the sooner you all reply the better. thanks
Username: Joe1234
Post Number: 1968
You mean 12w6v3 and are on sale for almost 500, likely two of those will be louder than a 15" properly setup, considerably louder not sure, neither sure about cleaner, Eclipse are also SQ subs(made by TC sounds which are some of the cleanest sounding subs around) maybe you have a bad box. Your amp is certainly entry level and may not be giving even rated power.
If you want considerably louder a couple of Fi Q 15 subs or something from ascendant audio for example, those are SQL subs that retain sound quality characteristics but are capable of much higher output.
A 3K amp would be nice for the Qs along with a number of electrical system upgrades.
