Image Dynamics CTX124
Username: Nitecrawlr
Hi there, I'm trying to find out of Image Dynamics subwoofers are any good, specifically the Image Dynamics CTX124... or of there's something better in the price range
Username: Joe1234
Post Number: 1771
Super entry level subs but Image Dynamics higher end gear is top notch for sound quality and very expensive, don't expect to get much loud with this subs.
Thanks for the info. The system I'm working with is just a mid-range whatever system. I'm just looking for something to round out the low-end... I just want to make sure that I'm not buying crap.
Username: Joe1234
Post Number: 1774
You may want to know that these subs work on sealed boxes, like 1.3-1.5 cubic feet net with added polyfill, ported box would be gigantic. If you want ported I wouldn't recommend them for that reason.
