Thoughts or suggestions on a new amp/sub combo?
Username: Remotepheonix
So a few months ago I got a visonik package with an amp 2 12 subs and a box for $150, but a few days ago my left speaker blew out and it sounds like the same is starting to happen to my right one. Anyways, I've been looking at different products online and I figured I'd either go with another amp/sub/box combo from a different brand or just get 2 12s and an amp and use my old box if I could. Right now, I've narrowed it down to these in order of preference:
two p3s with a hifonics brutus
https://www.amazon.com/Rockford-Fosgate-P3D4-12-1200-Watt-Subwoofer/dp/B004UFHXNI
https://www.amazon.com/Hifonics-Brutus-BRZ1200-1D-D-Class-Block/dp/B0036B8URK
or the hifonics with 2 pioneers
https://www.amazon.com/Pioneer-TS-W3002D2-Champion-Series-Subwoofer/dp/B001P6ZHLK
a kenwood bass package with soundstorm amp
http://www.sonicelectronix.com/item_40294_1600W-Kenwood-SoundStorm-Complete-Bass -Bundle.html?from=857#tabs
a kicker bass pack with crossfire amp
http://www.sonicelectronix.com/item_37942_600W-Kicker-Crossfire-Complete-Bass-Pa ckage.html?from=857
I thought that if I'd get either of the first two that I'll just use my old box, but if I notice that the sounds off or something, I'll just try my best to make a box. So does anyone have any thoughts on any of these setups? I'm trying to stay under $500-600, but if you have any suggestions on other amp/sub combos please let me know
Username: Glasswolf
Columbia, South Carolina America
Post Number: 14715
forget the kicker and kenwood pre-packaged junk.
the P3 and Pioneer combos are OK, although for the money you could probably do better.
I would suggest you buy a single, higher quality sub instead of two cheaper ones.
