What kind of sub do i need?Help please
Username: Amb631
I have a swizz audio SDX1500 mono block amp. 1500watts@ 1 ohm.750watts@2 ohms.375watts @4 ohms.What kind of sub or subs would be best for this amp? I had 4 different subs that i blown.
Username: Joe1234
Post Number: 1267
You will probably be better off with two subs.
If you want to use the amp at two ohms:
http://www.sonicelectronix.com/item_16665_Pioneer-TS-W3002D4.html
Username: Amb631
What do you think about a Kicker VS12L72 or MTX TS8512?
Username: Joe1234
Post Number: 1272
Besides your original question VS12L72 is hell expensive, the TS8512 is ok but there are better for the price.
One thing you must be clear that poor electrical connections,wiring or battery/alternator in bad shape sometimes can cause a sub to blow, if your are experiencing ligths dimming or distorted sound sometimes the sub can blow even if it can take the amplifier's rated power.
Username: Amb631
So then i should get a power cap? I can get 1 L7 in a ported box for $350. Not too bad.
Username: Joe1234
Post Number: 1274
Just check your electrical and the wiring to the amp, you should have like 2AWG or 4AWG OFC cable running to the amp, redo all connections.
The L7 suspension cracks overtime but it will last a couple of years if new.
Username: Amb631
ok Thanks
