SPX amp and sub combo
Username: Zadams201
Richmond, Virginia United States
so i got a sub combo the other day and i hooked it up today. but there is no boom. i did everything right. can someone please help me.
Username: Livin_loud
MW2 Addict
Post Number: 3550
as of now, no, nobody can. it appears either you didn't do everything right or you have faulty equipment.
double check EVERYTHING. if it still doesn't work then give some symptoms of whats happening exactly.
Username: Joe1234
Post Number: 450
Yes, list you equipment models, an describe exactly what you did and if you had something there before or is your first sub install.
Username: Zadams201
well i did everything check every bolt and wire and whatnot and still the same thing no power for it so i have a image for you all to take a look atUpload
Username: Vc23
EastCoast, Michigan Dos Fi BLs
Post Number: 364
This diagram still doesnt help us help you. Yes from the looks of paint, you know the basic setup. Id check fuses, faulty wiring, make sure you have a good ground. You could check and see if the amp is actually getting power with a multi meter, just put the 2 rods on the pwr and ground and see if it reads any voltage.
Username: Joe1234
Post Number: 458
Well if you connected the remote to the +12 and left it there you may not have battery charge left by now..lol
Anyways did any lights on the amp came on when you connected?? or all off.
