Parallel and Series wiring?
GoGetter
I was looking at this http://www.rockfordfosgate.com/rftech/wiringwizard.asp and it showed me the ohm loads and everything and wiring and that good stuff. I need an expert with this one. If I wire 2 4 ohm DVC subs to a mono amp that is 1 ohm stable, what ohm load would I get if I wire one sub in series and one in parallel.
1.8 ohms, but the one wired in series will only receive half the power of the one wired in parallel
