My new build. 2009 Charger PICS
Username: Nd4spd18
Philadelphia, PA
Post Number: 11916
So I finally got my new equipment installed. I will start by saying my goal with this build was to keep a completely stock look, but make it sound great.
So lets cut the BS and get to the PICS
Heres the car, old pic when there was snow on the ground lol
Parts list for the system:
RE Audio RE6.5C components
RE Audio SRX12D2 subs
PAC AOEM-CHR3 factory HU interface
Sundown Audio SAZ-1500D and SAX-125.2
Components installed in the doors. The silver is dynomat, I always use it between speakers and baffles. Used adapter brackets to mount the 6.5" and tweeter in the factory 6x9 opening, but I had to mod the adapters on the grinder quite a bit, the holes were not big enough for these speakers. lol.
The door looks completely stock with the panel back on.
View of the battery / spare tire compartment with the trunk liner still out, fuse blocks mounted on the left.
Amps on the back of the seats.
I bought 4 subs since they were a deal at $100 each, and I was impressed by how loud it was... actually was WAY more bass than I need lol. So I took 2 of them out and sold em to a friend, so now I'm only running two of them at a 2 ohm final load to the 1500D, so getting ~800 watts. And it's still plenty loud.
And this way, the spare tire compartment is easilly accessible since the box doesn't sit on where it folds up. And I half half my trunk left.
The split rear seat can still have half folded down.
The car also had a spot in the rear deck where an 8" factory sub would go if it had the "premium" stereo. So I just cut out the sound deadener that covered it, and now the truck is vented into the cabin thru that opening.
I used a PAC audio interface to get RCA outs from the factory radio. Here you can see the radio with my iphone mount, and PAC audio bass level control.
Questions / comments welcome.
Username: Kaerfpl
Spencerport, NY USA
Post Number: 1174
Looks good. How do those RE Audio components sound? I've always been curious and tempted to buy em' myself.
Username: Wolf_hound
Phoenix, AZ
Post Number: 1409
looks great. Those chargers have some big azz trunks
Username: Somedonniedude
Illinois Braaap MX
Post Number: 3193
Lookin' good! still have the blazer or is it gone?
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 1265
Nice man! Looks really clean...
btw, what did you use to mount those amps on the back of the seats?
Username: Nd4spd18
Philadelphia, PA
Post Number: 11917
" How do those RE Audio components sound? "
Awesome is how. lol. They are easily the best $130 speakers out there. They sound I'd say 90% as good as the $350 set of CDTs in my truck.
" still have the blazer or is it gone? "
It is gone, but my I miss that little old truck. That thing served me well for 7 years and 80k miles. Had 210k on it when I sold it and still ran great. My new truck is a 94 Chevy 1500 so I have that and the charger now.
" what did you use to mount those amps on the back of the seats? "
Just hardware store zip screws into the metal frame of the seat back.
Username: Nd4spd18
Philadelphia, PA
Post Number: 11918
There's both trucks
Username: Joebruce
Crescendo Audio FTMFW!!!, AA Havoc 15 ... Your Mom FTW!!!
Post Number: 3624
Nice car and nice install! Very clean and simple.
Username: Southernrebel
Post Number: 8510
Is that the Xscorpion cable and connections, MS?
Did you have enough?
Username: Van_man
Boston South, MA
Post Number: 5488
Very nice..Clean. Nice job with the door panels.. Looks alot better then the Spongebob Squarebox ones you had in the blazer.
Username: Nd4spd18
Philadelphia, PA
Post Number: 11921
Hey those square ones worked great... lol. I recovered them in blue carpet and they are in the truck now haha. Both trucks have the same issue, no depth available in the door to mount speakers, stock ones are in the dash.
@ Canaan, Yes I used all the wiring and accessories you sent me, thanks man. Had to run down to the local audio shop for one extra set of ring terminals but that was it.
