i just bbought an s10 and have plans of building a wall in it. With 4 JBL P1224,s on two kenwood 1800's. Amps could change. But i was wondering for Four 12's would it be loudest ? wall ,port center toward dash. or could i go just a long box horizontal port forward? spl and sq kept in mind, more towards spl though
As far as a wall goes, I would personally use two 15's or two 18's if they would fit. Also, the Kenwood amplifiers will have to go. I'd suggest selling them and purchasing something that's actually a reasonable amplifier.
Keep in mind your going to have to upgrade your electrical system in order to run all of this.
Crescendo Audio FTMFW!!,
AA Havoc 15 ...
Your Mom FTW!!
Post Number: 3665 Registered: May-04
LMAO!!!
No guys he didnt buy my POS truck lol!!
But hey Justin you will be needing a HO alt for a build like that,I jus so happen to have a 230amp for sale that fits S10s!! I also have a roll pan for sale too!! Ill cut you a great deal if you buy either or both!
The most space & cone area you could properly fit is 4 15's in 3-4 cubes NET each. Lots of those builds out there, search google. 4 18's or 6 15's sealed would be cool too.
im goin to try and jam another alternator as i have an extra, my kenwood is not 1 ohm stable so yes it has to go. im using 4 jbl 4 ohm dvcs so amps will be tricky to get as im on a budget. Big 3 upgrade and 1 or 2 more batteries. HO alt would be nice but im on a budget as i said. -no its not from kentcky lol michigan and black. -
