New member Username: GatordanglesPost Number: 1 Registered: May-11 | I'm really confused about the amount of power I need to power this subwoofer, its in a custom ported encloser if that helps. Please point me in the right direction. Examples of what woiuld be good? Would this amp work well? Sony XM-ZR1252 2-Channel Car Audio Amplifier @ eBay |
Silver Member Username: AlonzoubPost Number: 153 Registered: Apr-10 | Kicker CVR 12" can handle 400 watts RMS. You said its the 4-ohm model so it has two 4-ohm coils. What you will want to do is wire the 2 coils in parallel to get a final load of 2-ohms. Like this: Now you will want to look for MONO (that is 1-channel) amplifiers that can output 400 watts RMS into a 2-ohm load. Something like this: http://www.sonicelectronix.com/item_22381_Pioneer-GM-D7500M.html |
New member Username: GatordanglesPost Number: 2 Registered: May-11 | Thanks!! This all makes a lot more sense to me now. Are there any other specific amps you would recommend? |
