Lanzar OPTI1222D VS Kicker 12'' CVR
Username: Alex2342
which 1 will be better for a small size ported enclosure? i prefer quality and deep bass over loudness. thanks for any help
p.s price is the same for both drives so need to make a quick decision.
Username: Mystre
Pemberville, Ohio USA
Post Number: 752
I believe that you could do much better. What's the price?
Username: Mystre
Post Number: 753
Oh and if I had to choose, Keeker!
Username: Alex2342
i can choose any of these for free. this is gonna be my first car subwoofer and i want to choose the better 1. i've done a bit of research and looks like kicker 12'' cvr is $86 on amazon com and opti drive goes for well above 100.
opti is 900watt rms
kicker 400 watt rms
loooks like opti has a bigger magnet, so is it better? i have no clue... i'm so noob...
i've read that these opti drives are best in lanazar's series but i'm not sure.. that's why asking to help out
Username: Dloco486
Post Number: 22
what kind of amp are u goin to use with it. and what is the ratings rms watts@ohms. and how small is the box?
Username: Dloco486
Post Number: 23
and which voice coil does that kicker have?
Username: Alex2342
http://www.lanzar.com/itempage.asp?MODEL=OPTI1222D
and this is the kicker model
http://www.amazon.com/Kicker-CompVR-07CVR124-12-Inch-Subwoofer/dp/B000N8MW8C
and this very cheap box
http://www.solid.speakers0.us/1-493964-B000E245ZA-RT_300_Enclosure_Series_314_12 _Single_Slot_Vented_12_Sub_Bass_Hatchback_Speaker_Box.html
i bought pyramid 1600 watt amplifier off ebay if that helps.
Username: Dloco486
Post Number: 26
with that amp if your got a choice ild get the 2 ohm dvc Kicker CompVR 07CVR122. just type that in on amazon its right under the 1 your getting. i dont know if somebody is goin to buy it for u or if some 1 is giving it to u but your amp u got is only going to push 150 watts rms bridged at 4 ohms which is y u would need dual 2 ohm voice coil. u can wire it at 4 ohms. the duel 4 ohm voice coil will only do 2 ohms or 8 and if u wire it at 8 ure only lookin at about 50 watts maybe less. and if u bridge a 2 ohm load it will clip ure amp. that amp wouldnt work for that lanzer. it doesnt put out nowhere near the amount of power u need for it. a sub that would be better with that amp if u can get it though would be a diamond d1 at 2ohm dvc better than the kicker. but the kicker is goin to sound better with that amp than the lanzer.
Username: Alex2342
i know this audio set up must be the worst on this forum but it's all free for me anyway and it's my first set up ever. i will throw it away after a while and do some real upgrade in the future when i buy another car. for now i just need a bit of bass because my standart speakers won't pick up any low notes.
kicker then kicker. thanks for suggestion.
Username: Dloco486
Post Number: 27
http://www.amazon.com/Kicker-CompVR-07CVR122-12-Inch-Subwoofer/dp/B000N8MW8W
that is the link for the kicker
http://www.amazon.com/DIAMOND-AUDIO-D112D2-2-Audio-Subwoofer/dp/B0039538LG
that is the link for the 2ohm dvc diamond d1. it says 200 watts rms but the rms is is really 250 but it would be a good match for ure amp. and its a good price for a new 1. ild go diamond audio over kicker any day!!!!!!!!!
