W7s
Username: Basshead94
Centralia, Illinois United States
Post Number: 41
i got two 13.5 w7s and a t3000.1 amp how should i wire this setup up
Username: Lord_huggington
Ontario Canada
Post Number: 359
Google "subwoofer wiring diagram", and "wiring your subs: single voice coil" or "wiring your subs: dual voice coil".
Username: Livin_loud
MW2 Addict
Post Number: 3440
$20 says you don't have enough electrical upgrades to run that.
Username: Skdooley
Roanoke, VA Usa
Post Number: 1557
Wire each sub in series then run the pair parallel.
Username: Makinblak
Monroe/Monticello, La/Ar
Post Number: 575
They are 3 ohm right?
Username: Skdooley
Roanoke, VA Usa
Post Number: 1558
Dual 1.5 ohm.
Username: Perfectcircle
Naptown, Indy
Post Number: 294
You need to run them in parallel. amp would see 1.5 ohms. with that amp maybe around 2k watts. that would be about right. i am running 2 of those on my 2 wardens and they are huge power hogs. need to make sure your electrical is up to par or you will smoke that amp and possibly your subs from the voltage drop. they really pull a lot of power.
Username: Makinblak
Post Number: 588
What kinda wardens you got pike?
Naptown, Indy
Post Number: 295
21"s they're nice, but going to switch up soon. Just bought a third soundstream xxx 18 and i'm going to go in that direction.
Post Number: 42
sorry for the latteee reply but they are dual 1.5s
and i have the big three upgrade and a 10 farad rockford cap but my internet is very slow and pictures are 10x slower could one of you possibly upload the diagram on here or send it to me in an email @ mitchellznae@ymail.com and i can check it on my fone
Username: Van_man
Boston South, MA
Post Number: 5466
Nice subs.
heres a link to jl subs wiring.http://mobile.jlaudio.com/support_pages.php?page_id=161
2 DVC drivers with Voice Coils in Series / Parallel = 1.5 ohm load. Your best bet.
Or
2 DVC drivers with Voice Coils in Parallel / Parallel = .38 ohm load if your feeling lucky.
Post Number: 43
im most likely puttin them in a cts
wat size box do i need
can anyone help with the dimensions
and wat size port i need
