Should i stick with 2 15" CVR's or try out 4 10" Cadence's???
Username: Jordon32990
Hagerstown, IN
Post Number: 214
I am stuck between to setups. Should i keep my 15" Kicker CVR's or trade them for 4 Cadence UD104 subs?
The 15's are 500 rms each the 10's are 300 rms each.
I currently have a 1000 watt @ 1 ohm Planet Audio amp (VX900.)
For the usual Ecoustics members who are wondering, yes, I change my setups a lot, what can I say? I like trying out new subs. =]
If anyone has experience with either of these subs please inform me, perhaps some pros and cons??
I am sure I will get some good feedback.I always do.
Thanks to all in advance.
Username: Southernrebel
Post Number: 8490
Well...I know the CVR's capabilities, but the Cadence UD104's????
From my hands-on w/ the old UD's, they hands down outperformed the CVR's from the same year.
But, for the new UD's....all I can say is this....
They look like the spawn of 2 inbred cousins.
The new series baskets are similar to Quantum Audio subs (cheap Chinese made). But I have not hands-on experience w/ them.
I am a dB Drive dealer (sister company to Quantum), but have no experience w/ any current Quantum subs. Nor Cadence's lower lines.
The high-line cadence is a DIRECT copy of the AudioQue HDC3, but I don't know about the lower stuff.
Hagerstown, IN
Post Number: 215
The new UD's, are those the ones with the metal spearhead looking thing for a dustcover?
Username: Lord_huggington
Ontario Canada
Post Number: 351
Aren't the CVR 15's 750W RMS?
Hagerstown, IN
Post Number: 216
Every website I checked says 500 wrms.
Are these the old or new Cadence UD's?
Post Number: 8492
Those are the older Cadence subs (the ones I referenced in my earlier post)
They are HANDS DOWN better than the compatible model Kicker subs.
(verses same year model Kicker subs....$ for $.)
EDIT:
That model Cadence sub is ~3yrs old.
Username: Rovin
1 15 = 153 DBs ...Trinidad & T...
Post Number: 16970
2 15s = 353.25 sq"
4 10s = 314 sq" .....
Hagerstown, IN
Post Number: 217
Well I traded my Audiobahns for them. Did they have a 2 ohm single voice coil option?
Hagerstown, IN
Post Number: 218
These are single 2 ohm voice coils, just checked them. I need 1200 rms @ 2 ohm to push them fully.
