OT: No replies in speaker section... to much power for comps?
Username: Perfectcircle
Naptown, Indy
Post Number: 245
I had an older style rf t5002 running the comps in my tahoe. they are the re xxx 6 1/2s. they are 2 ohm. someone made me an offer on my t5002. i sold it to him. anyways, i have an older t8002. is it just to much power for them? i like a little head room but not 2 to 3 times rms? safe to do or get a new amp?
Username: Canaanwhite
Monroe, Louisiana USA
Post Number: 236
It should work fine as long as you don't clip the signal...
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 15807
its safe if you set the power amount you need with a digital multimeter plus it will be clean power
Username: Nd4spd18
Philadelphia, PA
Post Number: 11540
No such thing as too much power. You can keep the gain down and not use it all, and the more you don't use the better
Naptown, Indy
Post Number: 246
Sweet. thanks guys!
Post Number: 15945
your welcome
