Subwoofer/Amp wiring assistance needed desperately....
Username: Tornado112
ok I currently have 2 Audiobahn ALUM10N hooked up a a crappy amp that only pushes out 300 w rms... the name right now escapes me... i want to hook up an MA AUDIO SY5011DX
I need to know how to wire these 2 DVC 6ohm properly and the amp pproperly to get the most stable and best sounding subs that i can get the specs of both items below... This is a two channel amp and if you could tell me how to properly wire the terminals on both the amp and subs would be a great help.
10" Dual 6 ohms Aluminum Cone Subwoofer
Power Handling:
Peak: 1600 watts
RMS: 800 watts
Aluminum Voice Coil Former
Extended Pole Piece
Vented Oversized Back Plate
Flat Spider
120 oz. Double Stacked Strontium Magnets
Frequency Response: 20Hz -- 500Hz
Efficiency: 95.6dB
PHAT 1.75" EPDM Rubber Surround
Spun Aluminum 1-Piece Cone
3" 4-Layer Edge Wound Voice Coil
Dual 6 Ohm
3 Ohm or 12 Ohm Operation
Product Code: SY5011DX
Price: Check Latest
SPECIFICATIONS Model SY5011DX RMS Power @ 14.4V 4 Ohm 500W 2 Ohm 750W 1 Ohm 1000W MAX Power @ 14.4V 4 Ohm 750W 2 Ohm 1000W 1 Ohm 1500W Signal to Noise Ratio >96dB THD Level 4 Ohm 0.5% 2 Ohm 0.5% 1 Ohm 1.0% Frequency Response 10Hz - 350Hz 24dB Low Pass Filter 50Hz - 350Hz 24dB Subsonic Filter 15Hz - 50Hz Bass Boost Control at 45Hz 0 - 18dB RCA Input Sensitivity 0.2 - 8V Low level Input Impedance 22K Ohms Damping Factor 200 @ 4 Ohm Fuse Rating 40A x 4 Dimensions (W x H x L) 11.6 x 2.56 x 15.9
MA Audio SY5011DX 2002 1000watts RMS@14.4v
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 820
Wire the subs in parallel/parallel to get a 1.5ohm load like in the top diagram
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=62
An just bridge it to the amp
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 15471
I also have to bride the amp to mono right and if that is the case how do i properly wire it
and thanks guys for your help
and do you think the setup is any good how would you rate the old school ma audio amp
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 822
Yea bridge it to mono. It would be - from one channel + from the other. It should be labeled somewhere on there. Dont know much about ma,but your only going to get around 400wrms to each sub,which is about half there rms. Im sure they will sound fine on that,but you could go bigger on an amp if you didnt buy it already.
I have an o2 900.2 OA900.2 amp would this be better. also i thought i would push more power in a 1.5 ohm load since the max power would be 1000 at 1 ohm or am i looking at this wrong
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 824
Yea it would be the other way,it would be slightly less. It does 750wrms @ 2ohms an 1000wrms @ 1ohm so it would probly do between 800 an 900wrms im guessing
Username: Banbanpom
I ever use probly do between 800 an 900wrms that ok.
http://powercaramplifier.com/
Username: Glasswolf
Post Number: 13886
why did you get 6 ohm coil subs and only buy 2?
6 ohm coils are designed to run in sets of 3 speakers for a 2 ohm load.
I have had these subs for years and didnt know any better... now that im older and have more knowledge about them... now i know... but I want to at least push them with the mono block to the best potential that i have with the equipment i have. So hopefully this should do and reading online it seems that these subs are good when pushed properly
Username: Glasswolf
Post Number: 13894
be aware that very few amps made will be stable @ 1.5 ohms if the amp is stereo and it's bridged. A bridged stereo amp presented with a 1.5 ohm load will see 0.75 ohms, so to speak, and will most likely shut down and go into thermal protection immediately.
after checking the amp it is a monoblock amp stable at 1ohm 1000RMS supposedly... after checking the specs online.
