Username: Skdooley Roanoke,
VA
Usa
Post Number: 1200 Registered: Oct-09
Sunday, September 12, 2010 - 12:04 GMT Not expecting miracles from a single 8, but if you guys had to choose, which sub would perform best: SA-8, RL-i8, or a DD 1508? No one has bought the 500/1 so I'll be running 500 rms one of these drivers.
Diamond Member
Username: Wingmanalive Www.stainles...
.ecrater.com
Post Number: 23460 Registered: Jun-06
Sunday, September 12, 2010 - 15:47 GMT I'd go with the RL but most here would say the DD.
Username: Gcs8 Atlanta,
Ga
Post Number: 1315 Registered: Sep-09
Sunday, September 12, 2010 - 16:29 GMT i would want to try the sa-8, have heard good things about it. but if you want a higher quality driver the RL or DD.
Username: Southernrebel Monroe,
Louisiana
Team Audible...
Post Number: 8243 Registered: Mar-04
Sunday, September 12, 2010 - 20:00 GMT I'm a little bias, but I have seen and built some sick setups w/ the DD1508's. So my vote goes to DD1508d4 w/ your amp. (they are available in D2 now also) I like to match them up w/ the DD C2b (500w+) @ 2ohm. They are pretty picky when it comes to box design and loading though.
VA
Usa
Post Number: 1201 Registered: Oct-09
Sunday, September 12, 2010 - 21:27 GMT What would you say is an idle enclosure for a DD1508 would be Canaan?
Username: Insearchofbass 2 hifonics 2607s,
2dcSounds12xls
SPL\idmax12SQ
Post Number: 15247 Registered: Jun-04
Sunday, September 12, 2010 - 21:34 GMT go for quality do the rli 8
Username: Rovin 1 15 = 153 DBs ...Trinidad & T...
Post Number: 16668 Registered: Jul-05
Sunday, September 12, 2010 - 22:08 GMT never heard any of them but if i had to pick it wud be along the lines of sq like sean said : SS ...
Louisiana
Team Audible...
Post Number: 8245 Registered: Mar-04
Sunday, September 12, 2010 - 22:27 GMT Enclosure will be totally dependent on vehicle.
VA
Usa
Post Number: 1202 Registered: Oct-09
Sunday, September 12, 2010 - 22:58 GMT The enclosure I had in there was tuned at 32 Hz and it peaked in my car at 45 Hz if that tells you anything.
Username: Dsmith07 NC
Http://com4....
Post Number: 953 Registered: Jun-06
Monday, September 13, 2010 - 00:40 GMT sundown 8's , they are supposed to be pretty cheap to recone.
VA
Usa
Post Number: 1203 Registered: Oct-09
Monday, September 13, 2010 - 02:33 GMT Does AQ make an 8" sub? I saw a video of an 8" sdc, yet can't find one on their site. Anyone know anything about that sub?
2dcSounds12xls
SPL\idmax12SQ
Post Number: 15249 Registered: Jun-04
Monday, September 13, 2010 - 02:38 GMT pretty sure that was a proto type....get the dd if you go that way they arent expensive from what i remember
Louisiana
Team Audible...
Post Number: 8248 Registered: Mar-04
Monday, September 13, 2010 - 05:29 GMT AQ did offer an 8" for awhile...it was the old SD series, back when they offered 3 lines (SD, SD2.5, HD3) They dropped the US-made subs and have all motors built in China now. Thus the "C" in their current lines.
Ga
Post Number: 1325 Registered: Sep-09
Monday, September 13, 2010 - 06:09 GMT boo China.
Username: Deadrabit Marionville,
MO
Post Number: 2544 Registered: Jun-07
Monday, September 13, 2010 - 12:53 GMT hey... i like china
Post Number: 16672 Registered: Jul-05
Monday, September 13, 2010 - 15:52 GMT nothing is wrong with china in fact ALOT of stuff comes from there because of cheap labor - i bet even if u check ur underwear u will see made in china ...lol alot of parts from the top audio brands r made in china just designed & hand assembled in the usa ...
VA
Usa
Post Number: 1204 Registered: Oct-09
Tuesday, September 14, 2010 - 12:04 GMT Hey Canaan, what do DD 1508s with a carbon fiber dust cap retail for? How much do you think they're worth used in good condition?
