I have a 1998 Nissan Maxima with a 200-watt stock bose system and I was wondering if anyone can tell me what the best subwoffers to add to this system would be? Thanks
What are you looking for out of your subs? How much power are you looking to run? What kind of budget are you trying to stay within? Are you trying to maintain any trunk space?
I'm looking for more low end. My speakers already have a lot of low end but its not a solid low end and I want a sub that will give me a solid low end. I don't know how much power I need either. Will I need an amp for the sub as well? I don't want to spend more than $400. Also I still want some trunk space.
dustin ur forgetting box and wire kit... look at the american bass XD if u want a ported box http://www.caraudiodeals.com/american-bass-xd1544-p-1947.html or the 12 http://www.caraudiodeals.com/american-bass-xd1244-p-1955.html
if u want a sealed box this is one of my fav subs! i would get this over stuff that cost a lot more! great sound quality. if u got a pair of these RSD12s in a sealed box it would be nice http://www.buy.com/prod/phoenix-gold-rsd12-subwoofer-50w-rms-500w-pmpo-phoenix-g old-rsd12/q/listingid/42168091/loc/111/203087525.html
wire kit like this http://cgi.ebay.com/KnuKonceptz-Blue-Silver-KLM-4-Gauge-Amp-Install-Kit-/3802630 55545?pt=LH_DefaultDomain_0&hash=item588971c0b9#ht_4131wt_1137
i think this amp is an ok deal. i was thinking about buying one myself! http://www.sonicelectronix.com/item_17801_Eclipse+XA1200.html
if u want sounds quality get a pair of those RSD12s with that amp in a sealed box... i promise u it will sounds amazing and get pretty loud too!
if u want something louder look at a ported box and those american bass subwoofers.. but i think after u get a ported box made and a bigger amp it might be over 400 and take up most of the space in ur trunk.... if u can make a box on ur own that would really help out .
I was looking around at best buy.com i found these,
Head unit: http://www.bestbuy.com/site/Alpine+-+45W+x+4+In-Dash+CD+Deck+with+Flip-Down+Deta chable+Faceplate/9176198.p?id=1218045946194&skuId=9176198 or *http://www.bestbuy.com/site/Alpine+-+50W+x+4+Apple%26%23174%3B+iPod%26%23174%3B/Satellite+Radio/HD+Radio-Ready+In-Dash+CD+Deck/9215413.p?id=1218060486350&skuId=9215413*
