Suggestions please!
Username: Oscarbarrera
Post Number: 12
hey everyone i have 2 10" kicker comps and i am wondering if yall can help me out with giving me advise on what amp would be the best for my 2 subs.
heres some info on the subs them self
•10" 4-ohm subwoofer
•power handling: 50-150 watts RMS
•peak power handling: 300 watts
•frequency response: 30-500 Hz
i will really appreciate the help, thanks!
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 721
http://www.onlinecarstereo.com/CarAudio/p_20936_Infinity_1300a.aspx
http://www.sonicelectronix.com/item_21954_Kicker+ZX400.1+-10ZX400.1-.html
http://www.sonicelectronix.com/item_12247_JBL+GTO3501.html
Just a couple of the top of my head. Whats your budget?
Post Number: 13
thanks! and i dont really have a budget at the moment im jus trying to get some advise on amps and get an idea on which ones would be best suitable for my little system.
and i have a question, since i have 2 subs with a peak of 300 watts would i want to get a amp with 300 watts power or 600? and would i want a mono amp or a 2 channel? sorry im new to car audio im just 17 and would like to get some help from the people on this forum.
Username: Skdooley
Roanoke, VA Usa
Post Number: 1120
RMS is what is important. You'll need an amp that will produce 300 rms. Go with a mono block amplifier. If those are single 4 ohm woofers, then together they're going to run at 2 ohm. You'll need an amplifier that will produce 300 rms at a 2 ohm load. Shouldn't be very expensive at all. You could also go with an amp that will produce a little more power at 2 ohm than 300 rms to give yourself a little head room. That way if voltage drop occurs, you'll still be getting a clean 300 rms.
Post Number: 14
Theyare both dual coil .. So will i need a amp at 4 ohm?
And the amp will need to be 300 watts at 4 ohm?
Post Number: 15
Oh excuse me I got confused with the coils they are both sing coil
my mistake
