Heat Issue in sealed box?
Username: Silvermopar
Nebraska
Post Number: 198
Have any of you guys ever had any problems with a woofer getting hot in a sealed box. Where it cannot ventilate, it does not get cool air in. Was going to stuff my box a little, and it's been over an hour since I had the subs playing, but dam, the magnet on back is still quite hot. Is that normal?
Username: Deadrabit
Marionville, MO
Post Number: 2525
turn down ur gain... or dont set it in the sun
Nebraska
Post Number: 199
I avoid sitting in the sun, but black carpeted box, thats sealed up and a woofer inside doing it's thing, I guess maybe they just gotta get warm. I've never checked them, just noticed it when I pulled the sub to stuff it.
Diamond Member
Www.stainles... .ecrater.com
Post Number: 23351
Well I suppose you could invert the sub to eliminate the problem but then you'd have to add ballast to offset the reduced displacement lol.
Nebraska
Post Number: 200
Haha, I guess it's not a big deal then huh?
Username: Nd4spd18
Philadelphia, PA
Post Number: 11319
The only time I've ever seen a sub get hot is when the user was clipping it...
Nebraska
Post Number: 201
Hot or warm? What would you say is too hot?
Username: Skdooley
Roanoke, VA Usa
Post Number: 1121
I agree with M.S. As long as you're not over powering the woofer and you're not sending a clipped signal, there shouldn't be any danger to the sub.
Diamond Member
Post Number: 23358
Agreed. "Hot" is never an intentional design norm when producing subs, or anything electrical for that matter.
Excess heat+electronics=failure, immediate or eventual.
