2 12'' JL W3's
Username: Bking10
What would be the best kind of box and best amp for these subs?
Username: Thelonewolf1985
Post Number: 18
dont do it! overpriced!
Username: Rovin
1 15 = 153 DBs ...Trinidad & T...
Post Number: 16568
go with what JL recommended on their site for an enclosure
seems optimum power is 300wrms so it depends on if ur also buying a JL amp or some other brand ...
Username: Nickadam55
Columbia MO, Missouri
Post Number: 102
Vented for sure
Username: Mystre
Pemberville, Ohio USA
Post Number: 359
Depends on what type of music and what type of bass your looking for. I had 2 of those on a JL 500/1 in a sealed box and they pounded real hard. If your looking for tight bass go with a sealed box, if your looking for more of a rumbling go with a ported box. Also, if you need a box try Bassman3's website: http://www.dldesignz.com
Really nice guy, awesome prices and some of the best work I've seen.
Username: 813thumper
Tampa, FL United States
Post Number: 191
first off what version? v1 v2 or v3?
