Actually, not a bad amp.
Username: Jemone
Tucker, Georgia United States
Post Number: 372
I got an Audiopipe 1800.1d, and it as not that bad of an amp. It is a bit overrated though ( requires only a 120 amp external fuse).I Do not see how they say 1800 watts rms at 1 ohm load, but hey,they are quite affordable.
Username: Gcs8
Atlanta, Ga
Post Number: 885
14.4*120=1728*.8=1382.4 give or take, you can make more power with higher voltage or a higher THD %.
theres a lot of argument that that math wont give you what it can put out but it gives you a good ruff estimate.
Username: Kyle_lowe
Post Number: 1184
check for internal fusing as well
i have heard they do rated, but i would like to see a bench test to know for sure
Username: Gcs8
Atlanta, Ga
Post Number: 887
x2
Username: Nd4spd18
Philadelphia, PA
Post Number: 11183
Well whoever heard that does rated power heard wrong... very wrong..
The math above is actually a generous estimate but it shows the important thing, that its absolutely impossible for that amp to do the rated power. Actual output will be less than ~1200 watts.
And then the name audiopipe is on it, that right there tells you its gonna suck.
Username: Gutteer
Fort atkinson/Marshall, WI
Post Number: 111
yea i heard audiopipe and i thought crap because those names are reversable like that
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 14871
they are over rated a friend of mine and my brothers bench tested one and it was around that 1200 watt rating
Username: Boston_spl
Highland, CA United States
Post Number: 306
LoL
