Trying to Decide what would compare
Username: Dbaez02
Right now i have 3 Kicker Compvr 12's in my Acura integra powered by a power acoustiks 1 channel 4000 watt amp. I recently got a Lexus is300. My 3 12's will take up the whole trunk in the car and i would like to be able to still use it for baseball equiptment but still have bass. I was thinking of selling the 12's and just getting 1 kicker L7 or L5 15" or Alpine type R 15" ...whatever i get will be powered by the same amp. ...Any suggestions on subs?
Username: Boston_spl
Highland, CA United States
Post Number: 166
What amp do you have? (Not the wattage, the model #)
Also, from personal experience, I wouldn't recommend solo-baric's (Kicker's square subs). Unless ALL you care about is SPL, and even then I wouldn't recommend them (unless you can come up on them for dirt cheap).
Username: The_image_dynamic
San Diego, California
Post Number: 5756
Well first of all you can lose at least half that RMS rating you gave your amp. That's just how PA rolls. Second, Kicker subs sound like goats farting through a microphone -- you aren't moving up from much.
Have someone make you a cab for one Fi BTL 15 (2 ohm) that leaves some space all the way across at the rear of your trunk for your baseball gear. That amp will push it nicely until it croaks.
https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=154c18828468016/shopdata/0050_Speakers/0010_BTL/product_overview.shopscript
Username: Skdooley
Roanoke, VA Usa
Post Number: 852
I'd say a 15" Fi SSD on a Nine.1 or AQ1200D would be plenty for your car.
Username: Dbaez02
The type of amp that i have is the PS1-4000D. I have had problems with it already blowing, luckily it was still under warranty when it happened. So if anything i might sell that too and just get another one.
Username: Rosrock
Michigan
Post Number: 372
good idea
Post Number: 167
Very, good idea.
Sell that thing and put the $ you get from that towards an AQ1200D.
Is your Integra a hatchback or a 4-door?
Username: Dbaez02
It is a hatchback
