Box size : }
Username: Itatum
Post Number: 49
Specifications
Model SDC2.512
Woofer Size 12
Fs 32 H
Qts 0.471
Qes 0.533
Qms 4.085
Vas 36.7
Le mH 1.90 1.89
Sensitivie dB 88
Magnet Weight 140 oz
Coil Diameter 2.5
Useable Throw 2.3
Continuous Power 600
Music Peak Power 1200
Mounting Depth 6.5
Circle Cutout 11.187
These are specs. for the audioque 12" i would like to purchase. What would be a good Cu. ft. of volume for the encloser ? I found a duel chamber slot ported box at 1.9 cu. ft. for each chamber would that be good for the speaker above. Sorry if i forgot something
Username: Rosrock
Michigan
Post Number: 322
are u looking for the best sq u can get out of it, all out spl, good lows, a mix of spl and sq or what
Username: Delsole
Post Number: 1622
I think AQ recommends in between 1.8 and 2.5 cuft per sub. So is that 1.9cuft before or after sub and port displacement?
Username: Itatum
Post Number: 50
i dont know about the sub but the port is included.
To boss , i would like good lows, or a good all round bass
Username: Tejcurrent
Post Number: 2274
That is after all displacement. I'd find out the tuning frequency on that box.
Username: Cwruck
Post Number: 188
if its a box off ebay or something like that its just after port displacement, so sub displacement wont really take up too much space, but it will take up some space and raise the tuning..
so just make sure the box is around 32-35 hz and not up there like 40-42 hz
you want around 35 hz to give you a good sound with those 12s, they will pound hard man, i was thinking about getting some for myself but i never did
Username: Itatum
Post Number: 51
the boxes that ive been looking at are from sonic electronics. I called them about the duel 12" slot port box that i wanted and they said the box was tuned to 40 hz and there is no need to go any lower than that. He said that you would not hear the bass you would feel it. He also said that if i was going to increase my power that i sould get sealed boxes. So now im pretty confused on what to do. i am going to buy the sub that i posted at the top so i guess im not sure what encloser to buy for them. Im thinking of getting another D2200 amp, and have an amp for each sub but i dont want to have to get a different box if i do the two amp thing.
thanks for all the help.
Username: Bonhamd
Traverse City, MI
Post Number: 2197
dont listen to whoever told you that
below 40hz is definitely audible.....tuning 40 and above is generally considered high tuning - atleast for a daily driver
Username: Rovin
1 15 = 153 DBs ...Trinidad & T...
Post Number: 16365
do not buy sh1tty prefab boxes - get a proper 1 built by bassman3 on here ....
Username: Deadrabit
Marionville, MO
Post Number: 2434
"I think AQ recommends in between 1.8 and 2.5 cuft per sub. So is that 1.9cuft before or after sub and port displacement?"
were did u see that>???????
i think 3cuft would be loud spl.
around 2cuft would sounds great and get very loud also
Username: Rosrock
Michigan
Post Number: 325
^^hes talking about 2.0 AFTER displacement zeke.. generally when people reccomend a box tuning wise and cu ft wise they mean after displace
Username: Itatum
Post Number: 52
thanks for all your help
. Im going to try and find someone local to build a box, or at least get a price on what it will cost.
But sould i buy the subs first so they can factor them in to the plans.
Username: Bonhamd
Traverse City, MI
Post Number: 2198
save your self the trouble. just have bassman do it
he does great work and will do it for a good price
i doubt you will find anything comparable to his craftsmanship and cost
Username: Deadrabit
Marionville, MO
Post Number: 2439
i was saying 3cuft after displacement. bigger box
Username: Cwruck
Post Number: 204
you dont need to have the subs for a box builder to make you the box, just let them know the dimensions of what u want and the cu ft after displacement, they can figure it out for you, but i say just make the dimensions yourself and measure the box when its done, if the dimensions are off, either dont pay for the box or talk them down on price since they messed up
Username: Nd4spd18
Philadelphia, PA
Post Number: 11121
As stated here already. do NOT buy a prefab ported box... they are all tuned wrong.
Username: Itatum
Post Number: 53
ok thanks for the info. how do i get in touch with bassman.
Username: Dustin3
Box Designer & Builder...Dustin
Post Number: 5623
Hi Zeke ~
You can email me at DLaudiotech@gmail.com
