KICKER L7. NEED HELP PLEASE!
Username: Zepurcel
I bought a 15 inch kicker L7 solo baric subwoofer. I can not find dimensions for a good box on the internet to save my life. I drive an avalanche. I am taking out the piece that separates the cab from the bed so i have plenty of room for a big box. The kicker website recommends between 3-6 cu ft. I was wanting to be closer to 6 though. but building a ported box isn't as easy as the traditional sealed box (as im used to).
Can someone please send me dimensions for a ported box the would be premium for my subs? It would be greatly appreciated
Username: Glasswolf
Post Number: 13769
http://www.bcae1.com/spboxnew2.htm
use the speaker's T/S specs to calculate the box yourself using the above link.
Username: Stubbs563
Cedar Rapids, Iowa
Post Number: 96
since you cant find dimensions return it and get a different sub.
Username: Nd4spd18
Philadelphia, PA
Post Number: 11112
That would truely be the best idea... L7s are terriable
Username: Stubbs563
Cedar Rapids, Iowa
Post Number: 98
Ive had like 5 people (including the owner of the following system) say my single 15" ssd is louder than 3 12" l7s in the back of his roush in a cusom fiberglass box.... lool fail.
