One ohm stable amp
Username: Vincent_law
Ca
Post Number: 26
i am looking for some inexpensive amps. i am trying to power jl w7 13.
Username: Gcs8
Atlanta, Ga
Post Number: 522
how many watts do you need?
Username: Rosrock
Michigan
Post Number: 214
whats ur budget
Username: Gcs8
Atlanta, Ga
Post Number: 523
http://www.audioque.com/aq/?page_id=26
would be my choice for budget.
or http://www.soundsolutionsaudio.com/store/products/Sundown-Audio-SAZ%252d1000D.ht ml
Username: Skdooley
Roanoke, VA Usa
Post Number: 751
You're going to need an amp that will push 1000 - 1500 rms at 3 ohms. There really isnt going to be an inexpensive amp that is going to do that. The sub can be wired to run at 0.75 ohms, but I think you'd be better off running it at 3 ohms.
Ca
Post Number: 27
i want around 1000 to 1500 watts at 1.5 ohm... my budget.. well i 250 to 350 max. can it be done you know with amazon or ebay?
Username: Skdooley
Roanoke, VA Usa
Post Number: 754
A 13 w7 is dual 1.5 ohm. It can run at 0.75 or 3 ohm by itself.
Username: Van_man
Boston South, MA
Post Number: 5314
I would do the AQ 1200d wired down to .75. With box rise and stuff you should be around 800-1200 watts.
Yes the aq will take a .75 ohm load with a good electrical to back it up.
Also those alpine pdx ams do 1000watts from 1-4 ohms like the JL amps. There are a few others as well, but for budget, the AQ is the best bet imo.
Username: Delsole
Post Number: 1564
I would keep an eye out on Craigslist for a used Jl 1000/1. Through the past couple years i have seem many of them sell for around 350 bucks. Sometimes more sometimes less. You could even try ebay.
I think the jl 1000/1 would be ideal though.
Username: Cwruck
Post Number: 163
i would look at the jbl gto14001. harmon audio sells them on ebay and i see them go for 160 sometimes 1200 rms at 4 ohms 1500 at 2 so maybe 1300 or so at 3 ohms?? but has a max current draw of 140 amps at 2 ohms..
Username: Joebruce
TC Sounds/DLS
Post Number: 3021
I had the same problem finding an amp for my TC 4000 (single 3ohm) I needed 800-1500wrms at 3ohms. I finally got tired of looking and didnt want to pay out the a*s so I just got this http://www.sonicelectronix.com/item_7708_JBL+BPX500.1.html
I would guess Im getting around 700wrms at 3ohms but Im not sure. It powers my sub great tho. And I only paid like $120 for it
You could check this out
http://cgi.ebay.com/JBL-Amplifier-Car-subwoofer-sub-amp-GTO14001-Gto-14001-/2506 38811608?cmd=ViewItem&pt=Car_Amplifiers&hash=item3a5b3cc1d8
Or you could always get a 2ch amp like this
http://www.woofersetc.com/p128/GT28--Boston-Acoustics-2-Ch-1000-Watt-Amplifier.h tm
Username: Somedonniedude
Illinois Braaap MX
Post Number: 3058
Kevin H. who still gets on here from time to time has an RD 1000.1 v2 for sale, i think he was wanting $250 shipped and it's still brand new in box. They are said to do 1300+ watts @ 1 ohm, and will do even more @ 0.75 ohm.
