Help with sound cancellation
Username: Jarod027
Hey, so I have just finished making my ported box for two 12" kicker l5. 4.4c/f box, I have it ported out the back into the cabin, with the back seat down. But I have noticed that the bass hits much harder with the trunk open rather than down, and was told that was because of cancellation issues.
Is there anyway to correct this? Please help, i want to get the most I can out of my setup
Username: Rovin
1 15 = 152.5 DBs ...Trinidad & T...
Post Number: 16312
if ur trunk is rattling alot which might be affecting how the music sounds then u will need to sound deaden it with some expanding foam & some matting like second skin or dynamat ...
Username: Glasswolf
Post Number: 13613
I'm not sure I understand how you have the box set up. Any pics?
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 401
Yea,id like to see pics too. Have you tried facing your box the opposite way? Port facing the trunk?
Username: Hdubb
Team Revolution
Post Number: 4318
open your trunk lol.
Username: Skdooley
Roanoke, VA Usa
Post Number: 728
How much room is the box taking up in your trunk? If the box is really big and after closing the trunk, there isn't much room for air to move, it may be constraining the air movement. Almost like the subs being in a sealed enclosure vs. ported. Pics would definitely help though.
