Well, I finally got my Avalanche up and playing. There is a show in Pine Bluff, AR, tomorrow, so I figured I might as well throw my IA20.1 in there and get some points for the season.
Is wired to 1.5ohm right on the 20.1 now, but will have a pair of DDM2a strapped at 1.5ohm later (gotta get my $ together first).
Pretty tight squeeze through the front port.
Recessed baffles...yea, its dusty as hell in there, gotta vacuum it out.
The inside trim will be covered w/ vinyl. I just slapped it in there for this weekend. The little amp rack there is just a 49"wide panel to slap the amp in there also. I'll clean it all up when I get the 2 DDm2a's
Thru the port, 3/4" round over.
New decals on the avalanche.
Even w/ just the 20.1 @ 1.5ohm, its pretty loud and plays LOW. The roof goes crazy and makes it sound like crap when I get it loud, I gotta pull the headliner pretty soon and get some Second Skin in there. Thinking 2 layer should take care of it. Haven't metered it yet, but will at the show tomorrow. I can't wait get double or more power in there
