Square subwoofer cut outs
Username: Ericmb
Waycross, Georgia United States
Post Number: 324
doing a build for a guy with 2 kicker l5 15s here in a day or so.. would the easiest way to do the cut outs, be a jigsaw? this seems like its going to be quite annoying to draw/cut these things out.. anyone have any easier way?
Username: Rosrock
Post Number: 97
a guy that just built my 12 box at freaking abcwarehouse made my cout out diameter freaking 10.7 inches so sub wont even fit.. what a dumbass. sigh so yea that kinda ticks me off, make sure u dont mess that up
Username: Ericmb
Post Number: 325
actually thats probably not too far off.. most subs are kind of far from the real diameter.. like a cvx 15(using this because i just built a box for them) wasnt even 12 inches..
Username: Ericmb
Post Number: 326
said that wrong.. it was just barely over 13 inches.. sorry.
Username: Dustin3
Box Designer & Builder...Dustin
Post Number: 5561
Just draw out the radius and go at it with a jig.
Username: Glasswolf
Lexington, SC USA
Post Number: 13400
S15L5 subs?
mark the corners.
drill holes with a bit equal to the radius of the rounded L5 corners.
use a jigsaw to connect the dots and cut out the straight portions between the corner holds.
you end up with a square opening with smoothly rounded corners after a touch of sanding.
Username: 420pimp2
Baltimore Atlantic Ci..., MD, NJ
Post Number: 915
Blowtorch is by far the sh*t. Very clean cuts...
Username: Glasswolf
Lexington, SC USA
Post Number: 13424
I was going to suggest a plasma torch and some C4... but ordinances vary from state to state.
