Silver Member Username: Sleste8Shelbyville, MI United States Post Number: 129 Registered: Mar-10 | alright, i started a box today for a friend. its for 2 12's and he wanted another bandpass. can u guys give me some idea's on this one? how would you make it? tyvm. |
Platinum Member Username: GlasswolfLexington, SC USA Post Number: 13334 Registered: Dec-03 | 4th order, tune it for about 40-45Hz. It'll have terrific gain. http://www.diysubwoofers.org/bnd/4thorder.htm |
Silver Member Username: Sleste8Shelbyville, MI United States Post Number: 131 Registered: Mar-10 | man that page was pretty confusing for me, lol. i guess im just way over my head on this one. could you draw up a design for me? i understand if that's a no. buy the way glass, that slot ported enclosure for that single orion 12 turned out great. thanks for the help on that one. |
Platinum Member Username: GlasswolfLexington, SC USA Post Number: 13345 Registered: Dec-03 | good deal. tell ya what, google "bass box pro download" and "winISD download" get both of those programs and give them a try set for 4th order BP. See how that works. I don't have anything handy for designing a box right now. I'd have to hand draw it, and I gave away my drafting table when I moved. The software will show a response curve though, based on volumes for sealed and ported sides of the box. Find a curve you like. you'll notice that you'll be trading off between low frequency response (being more musical) and high output gain (tuned higher for "one-note" SPL response) That's pretty much how 4th order goes. If you want a flat, musical response, you can get it, but by then you may as well just go ported.. |
Silver Member Username: Sleste8Shelbyville, MI United States Post Number: 138 Registered: Mar-10 | ok glass, thanks again for the info. i'll give those programs a try and see if i can figure these BP box's out, lol |
