POWER ACOUSTIK OV1-3000D
Username: Andy614
Post Number: 40
is this amp good for my 2 12' dual subs?
Username: Skdooley
Roanoke, VA Usa
Post Number: 434
No, its got Power Acoustik all over it.
Username: Callmemrbunnz
Post Number: 7
lol actually that amp isnt bad. ive seen a few power acoustik systems that sounded pretty good like the power acoustik mofos and my brother uses that amp with 6 premier low line 12s with an eq and it gets retarted loud. hes been running his for a while now and not had a problem with his.
Username: Glasswolf
Columbia, SC USA
Post Number: 12954
loud does not equal quality.
Dual isn't so great either, but if you're on that tight of a budget, I suppose PA will do the job.
