IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE' Use the steering controls for code entry. Press the [ ] button then rotate the thumb wheel for the correct first digit Press the [ ] button then rotate the thumb wheel for the correct second digit Press the [ ] button then rotate the thumb wheel for the correct third digit Press the [ ] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [ ] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL press the first preset button for the 1st digit, second button for the 2nd digit third button for 3rd digit forth button for 4th digit then press buttons 6 OR 5 to store. for 10 seconds
note the radio does not lockout after a wrong code entry it only doubles the time to wait before the next retry...if a wrong code is entered it will display error then after the delay should display "0000")
Switch on the radio, the display will show 'CODE'(dc449/62)
Press [ 1 ] followed by the station <> buttons to rotate the first digit Press [ 2 ] followed by the station <> buttons to rotate the second digit Press [ 3 ] followed by the station <> buttons to rotate the third digit Press [ 4 ] followed by the station <> buttons to rotate the fourth digit
Finally if the correct code is shown on screen press the [ 1 ] button to save the code
BASIC INSTRUCTIONS TO ENTER A BLAUPUNKT RADIO CODE Switch the ignition key ON Press and hold AS button * and the ON button at the same time Display Shows SAFE then goes to 10 - - - - with a "Beep" from the speaker Press Preset Button " 1 "repeatedly until the 1st Digit of your Code is displayed Press Preset Button " 2" repeatedly until the 2nd Digit of your Code is displayed Press Preset Button " 3" repeatedly until the 3rd Digit of your code is displayed Press Preset Button " 4" repeatedly until the 4th Digit of your code is displayed If the display now shows the correct Code number then Press Button AS and hold to Enter and if successful there should be a "Beep" from the speaker and the radio should switch on
press the first preset button 1 for the 1st digit, followed by (station +) second button for the 2nd digit followed by (station +) third button for 3rd digit followed by (station +) forth button for 4th digit followed by (station +) then press (station+) to store
