Like
Square one
Username: Grmncrsnbr
VA
Post Number: 90
Well here it goes again since my idea was recently shot down. I need to find a good sub amp that will run at 2 Ohm, is mono, and puts out 500W Rms for my subs. Here is the kicker though, I want an amp that has like a matching 2 channel amp for when it comes time to wire my speakers that way its a good clean install. The we channel amp needs to be 100/ch at 4 ohms. Thanks in advance. oh and lets not get too crazy with the pricing
VA
Post Number: 92
well after doing some looking around on good ol ebay im gonna go with a Phoenix Gold amp. I know they good review on this site so i wont get al turned around and restarted again.
Username: Rswan
Post Number: 151
get an mtx 801d it will be great for what you want too do. they have a really good 2 channel amp that looks exactly the same too. you can get them both for around 600.
Username: Jayj
Post Number: 216
hey Grmncrsnbr What kind of price range are you looking at. So I can recommend something a little better for you. Oh and sorry about shooting down your other Idea but just telling what I've seen. If Glass or Jonathan told you they was good then go for them. Maybe the company was just having a bad day when they made those amps.
VA
Post Number: 94
Yeah glass said they werent a bad company, but i know the both of them like PG amps and since i actually found them for a little cheaper i think im gonna go ahead with them. My full system not counting head unit is looking at about $1400 and thats high enough for now I can always upgrade later
Glass/Jon if you read this which should i go with PG or Hifonics?
Username: Jayj
Post Number: 218
Hey I found those 2 PG amps. Try to see what kind of price you can get these for on ebay. I also like PG amps never seen are heard a problem about them. Heres 2 links for they amps check them out.
http://www.acaraudio.com/product_info.php?cPath=22_36&products_id=870
http://www.acaraudio.com/product_info.php?cPath=22_37&products_id=866
Username: Jayj
Post Number: 219
VA
Post Number: 96
hahaha those were the exact two i found on ebay the mono was for 210 shipped and the 2 ch was 146 shipped
VA
Post Number: 111
so yeah i lied about wanting those haha the listed values on the their website are max not RMS so once again im back to square one anyone have any ideas?
Facebook
Shop Related Deals
Directory
