Silver Member Username: DomenicoBanginGMCArizona Post Number: 394 Registered: Apr-09 | My KDC-MP342U turns cuts off and powers back on when my system is "bangin", i hard wired the h/u and used butt connectors made it real clean. So far it only cuts off at high volumes. 24+/30.. help? Stock alt, yellow top, 2 type r's, pdx1000. http://www.kenwoodusa.com/Car_Entertainment/In-Dash_CD_n_DVD_Receivers/1-DIN_CD_ Receiver/KDC-MP342U |
Platinum Member Username: Rovin1 15 = 152.5 DBs ...Trinidad & T... Post Number: 15846 Registered: Jul-05 | do u have a volt meter in ur set to show how ur current holds up ?.... |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10906 Registered: Jul-06 | Are you powering any speakers with the hu internal amp?... If so disconnect them and try it. But I think a more likely guess is you may have botched that wiring job somehow... Could try using stock power and ground wires and see if that fixes if |
Silver Member Username: DomenicoBanginGMCArizona Post Number: 396 Registered: Apr-09 | NOTE: Only happend in idol. (parked in drive way) havent tried driving it and seeing if it'll happen. - no plates on truck. Rovin - I have a fac. voltmeter, it drops down some.. i havent noticed how far tho. M.S. - Yes, some shitttt-tay pioneer and kenwoods that came with the truck already installed. Dash n pannels The first thing that popped in my head was the voltage dropping.. then like a safty curcit breaker type deal activates? |
