Hitting high notes better?
Username: Cplaya280
Pennsylvania USA
Post Number: 1006
I have a 15" Audiopulse Revo powered by the AQ2200D in a 32hz woodlawn box. Is there anyway to get the sub to hit the higher notes better it sounds really wierd in some songs. where high notes will be in the song and theres barly any output but once a low note comes in the sub kills it really really deep. I'm not sure if this sub just can't handle highs that great and kills the lows or what. Is there a settin on the amp i can make the sub hit higher or do i just need a higher tuned box. If i mess with the LPF would that help i know right now its set around 80-85. I also have the Pioneer Deh-7800p so idk if theres any special settin i should have on there. Any feed back would be great.
Username: Insearchofbass
York, Pennsylvania
Post Number: 13013
Sad to say but the only way you can fix this is to build a new smaller box if its on the large side. Whats happening is mostly cabin acoustics. You would also want to raise tuning.
Username: Cplaya280
Pennsylvania USA
Post Number: 1007
alright thanks alot
Username: Rovin
1 15 = 152.5 DBs ...Trinidad & T...
Post Number: 15840
maybe u can try adding in some blocks of wood to raise the tuning .......
Diamond Member
Post Number: 23597
the revo just don't hit the upper bass notes well. that is why i got rid of mine.
Username: B3n07
Louisville, Ky USA
Post Number: 1178
if you get rid of this sub i would be interested in buying it i have always wanted on
Username: Basshead86
Steady as she goes...
Post Number: 10634
definitely tune it higher first. if you don't like it then either sell it, or suck it up. :-)
Username: Rovin
Post Number: 15844
OR get ur up front speakers to play the higher notes
i gotten so accustomed to very low bass that i have my comps set at 50hz & sub amp lpf set at 50hz ...personally for daily SQ notes i dont like high sub bass ....
Username: Somedonniedude
Illinois Braaap MX
Post Number: 2903
how big is your box?
Steady as she goes..., FL
Post Number: 10640
yeah, you might need to do some crossover work to get your mids and highs working together with you sub.
Username: Tedsprogz
Nunya, Florida US
Post Number: 78
josh...whats good cracka call me you know the area code the number is 2862763
