Cd play
Username: Pontiacman22
Waukeshua, Wisconsin Us
ok i have a stock cd player in my 07 pontiac g6 and i want to change it out with an after market cd player but i dont want to lose the gauges that tell me how many miles my gas has and trip meter and so on what could i do?
Username: Joseito
as far as i know if you change the radio the computer's gona show the same as before, miles, trip and so on, just the radio station or cd (radio things)gona dissapear cause is a separate loom, try to remove your radio and see whats happens,make sure you got the code for it. good luck.
Username: Kelly123
Post Number: 7
If you don't want to lose the gauges, you can buy a cd changer install in your car. you can go to this http://www.car-cd-changer.net
Username: Kelly123
Post Number: 8
This idea is very good. http://www.car-cd-changer.net
Need to Register?
Forgot Password?
Enable HTML code in message
