Ultra light MDF vs Trupan
Username: Dlavante
D&L Audio Tech. , Daniel Tigard, Or, USA
Post Number: 231
from what i can tell trupan is just a brand of light mdf. does ultra light or light mdf have the same strength as trupan? has anyone constructed an enclosure from light or ultra light mdf?
Username: Deadrabit
Marionville, MO
Post Number: 2121
iv never seen ultra light mdf before.
but i have used trupan and ultra light true pan,
trupan is a type of mdf. its almost just as strong but lighter. i think that trupan is stronger for its weight
Username: Snowball123
West Allis, WI
Post Number: 3041
what about plywood BLK. Since your whole wall is made of it.
Username: Dustin3
D&L Audio Tech.Dustin
Post Number: 5068
BLK, How is the ultra light trupan as far as dealing with it and cutting?
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 7196
if your worried about weight.. your into the wrong hobby
Username: Dustin3
Post Number: 5070
no one said their worried about weight... If there is a product out there that is just as strong and it 60% the weight... its a no brainer for which one to use.
Username: Rovin
1 15 = 152.5 DBs ...Trinidad & T...
Post Number: 15409
have use both & major difference imo is really the weight & my powersaw cuts the ultra alot faster & easier ...
Username: Shade
Moxee, Wa U.S.
Post Number: 873
price diff?
Username: Dustin3
Post Number: 5072
same price ;) if you know how to find it
Username: Deadrabit
Marionville, MO
Post Number: 2123
the trupan cost more.
the trupan cuts better
plywood sucks. i wouldn't ever make a box out of it, its weak, snow doesn't know very much
