Would the KENWOOD KAC-9104D amp work well with 2 alpine type r's 12inch
Username: Hockeytoker
hi im sort of new to all of this car audio stuff.
i was wondering if someone could tell me if this amp
http://www.millionbuy.com/kenkac9104d.html
would sound good with 2 alpine type r's 12 inch 2ohms.
http://www.dealercostcaraudio.com/swr-1222d.aspx
i was also wondering if any of these would be a good box to put them in.
http://www.dealercostcaraudio.com/sev122.aspx
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=20154
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=20172
and the last thing i was wondering since the subs are going to be putting out about 1000 watts of power should i look into getting a capacitor?
any suggestions on any of this would help thank you.
Username: Ctmike
Ct.
Post Number: 6791
no, kenwood amps are garbage and should never be bought (nor recommended like you did earlier).
if getting a pair of type rs' and haven't bought them yet, get dual 4ohm. it'll be cheaper to get the power you'll need at 1ohm.
post a budget for an amp. cheapest amp you'll get that's quality would be the audioque 1200 for $249 shipped direct. many others out there, but it seems like you're looking to go cheap.
never get a prefab box. get a nice ported box made for the subs you buy.
and don't waste the money on a cap.
Username: Babymagik85
Fayetteville, NC Us
that amp will work but your subs would be a little under powered. If you get two of these amps you coud get very good results. Legacy, sony,audiopipe, pyle, crunch, are all pieces of junk compared to kenwood
Username: Cal1089
Post Number: 14
Jeremy Even Kenwood is crap. you can normally tell its crap if one ITS TO GOOD TO BE TRUE.
2 if they post the max on the listing instead of rms, that at least what i have learned
