Will my kickers blow?
Username: Wackzirth88
K-town, Il U.S.
I have 2 kicker cvr 12s 2 ohm 400 rms each and a hifonics brutus 1210d. i have it wired at a 2 ohm load which i believed was pumping 900 rms. But since ive been looking into ways to improve my system im seeing alot of people are saying hifonics brutus are overrated. Ive seen that they only push 800-900 watts rms at 1 ohm load. Im wondering if i wire my subs to 1 ohm, adjust my gains.Can the subs handle it? or good chance theyll blow. i definately dont want that but i do want as much bass as i can get with what i have.
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 3151
HOW ARE YOU GONNA WIRE THEN TO A 1 OHM LOAD? sorry about capps
it is a trick question.... It can't be done with those subs.
Username: Poprocks
Post Number: 129
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=22
Username: B3n07
Louisville, Ky USA
Post Number: 1046
no it wont work you will get a half an ohm load which will fry your amp. an im confused you said your giving your subs 900 wired at 2. if im not mistaken that amp wired to 1 ohm would give you 1200 or some where around there which ould fry the speaker
K-town, Il U.S.
thanks for your guys info. i understand now
Username: Hittin1
Post Number: 3158
The 2- cvr's if able to receive the full power of a bxi1208, would likely handle the amp if setup properly. I know it would not fry the subs immediately. but it is irrevalant as he has wrong vc configuration.
K-town, Il U.S.
Post Number: 11
i have my voice coils wired in series and my subs wired parallel.which is a 2 ohm load. i was wantin to wire them parallel/parallel but have found that would make a 1/2 ohm load and will fry my amp. so im keeping it how it is. i followed the wiring diagram from
Username: M0nstar
Toledo, OH U.S.
Post Number: 256
yes you CAN wire a pair of d2 subs to a 2 ohm load.
Username: Hittin1
Post Number: 3186
okay.. enlighten us Lucas.
Username: Hittin1
Post Number: 3188
he wanted a 1 ohm load not 2
Username: M0nstar
Toledo, OH U.S.
Post Number: 258
mark, you're kidding right????
wire the second voice coils on the speakers in series, so that each is at 4 ohms.
then wire them together.
ta-da. 2 ohms.
btw my bad i thought he DID need a 2 ohm load.
Username: Hittin1
Post Number: 3200
dude.. look at the 2nd sentence of the 1st post. So why would I doubt that you couldn't do it or that it couldn 't be done?. lol besides he just said how he did it a couple of post before you.
Username: M0nstar
Toledo, OH U.S.
Post Number: 260
hahaha dont do drugs kids lol
