Quick amp/power question
Username: Skateguy92
Post Number: 91
I have 4ga power ran for now (Was just using 1000-1200w) . I was wondering if it would be bad or if it was possible to hook up a 2000w amp but use a DMM to set it down to around 1000-1200w..... anyone?
I eventually plan on getting a HO alt and 0ga ran.
Username: Jtown
Texas
Post Number: 3741
sure it's possible, but why not go ahead and run 0ga? why get a 2kwrms amp if you're not going to use the power?
Post Number: 92
Well I can think of a couple reasons....
One being its too good of a deal to pass up and I need an amp in my car.
And another because not everybody has the time and money to get a HO alt and 0ga ran anda couple more woofers... I plan on doing it when I get the funds.
Basically I was just wondering if I could tune the amp down and direct replace it for now.
Username: Prozack52
Cincinnati, 2-audio puls...
Post Number: 531
save the money and do it right all at one time
Username: Snowball123
West Allis, WI
Post Number: 2653
yes it would be perfectly fine. what amp did you plan on getting?
Username: Nd4spd18
Philadelphia, PA
Post Number: 10362
Would I recommend it... no
Will it work... yes (as long as the power wire is properly fused with the proper size fuse for the wire size)
Username: Jkidder
Worlds gunna end, In 2012
Post Number: 4067
theres nothing whatsoever wrong with doing this.
Username: Talon01
Team dc audio, Pa Usa
Post Number: 2063
i would have to agree with ms
Username: Deadrabit
Marionville, MO
Post Number: 1639
what kind of amp is it?
Username: Vivi2000
Owosso, Mi
Post Number: 175
If you already have a 1000w amp i would buy the other one and just wait till you have proper electrical to install it.
Post Number: 93
it would be a AQ2200 if I get it
And I dont have any amp at now... my pos hifonics finally crapped out on me lol it lasted a while though
