Alpha recone...
Username: Killer44
Ontario Canada
Post Number: 1011
so im only running one of alphas off of my 1750.1 now and since they are dual4ohm i want to get one of them changed to dual2ohm...i think the guy from rd is on here so im posting this because ive emailed them a couple times a week or so ago and havnt heard anything and im wanting to do this asap...also anyone with an alpha recomend a good tunning for the box...i was gunna go with 34hz the box is 3cuft...thanks
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 2744
Steve will get you taken care of when he can... I believe his wife has been in the hospital.. 34 hz will be fine and if it is a 12" or 15" the box size will suffice.
Username: Killer44
Ontario Canada
Post Number: 1012
ok thanks mark...thats unfortunate, i hope all is well for him...is the rd site the best way to get ahold of him or should i post something for him on here...?
Username: Teamrevolution
ATLANTA, GA USA
Post Number: 571
If you have a alpha v.1 dual 4 the alpha v.2 dual 2 will not fit.
Send me an email to smiller@rdaudio.net with your info and i will see what can be done.
