Fi Q or BL???
Username: Craudi0
Post Number: 15
looking at the 12". it would just be one. just want to know differences and similarities. looking for something that gets loud, but retains sq as well.
Username: Deadrabit
Marionville, MO
Post Number: 1368
get the BL
Username: Surferdude9371
Get loud or go home....
Post Number: 1698
on a scale from 1 to 10, 1 being pure sq 10 being pure spl the "Q" would be a 2 and the "BL" would be a 7-8.
Username: Craudi0
Post Number: 16
why though? what's the difference?
Username: Craudi0
Post Number: 17
ok so the BL is louder, but the Q has better sound quality? and i would imagine that the Q is still pretty loud, considering it handles 1000rms
Post Number: 1699
its just how the woofers were built the "Q" was built as their sq line and the bl was their sql line. The "Q" deff still gets loud and if you add on the options it can handle even more power.
Username: Craudi0
Post Number: 18
ok so i mostly listen to rap and hip hop. overall, which would be best running at 1000rms or a lil over?
Username: Big_edge_head
Milwaukee, WI
Post Number: 3553
It's up to you. The bl might get louder but the Q should sound a little better. If it were me I'd get the Q because sq>spl imo.
Username: Craudi0
Post Number: 19
ya i think the Q is a better choice, because better SQ, and it will still be REALLY loud. 2 cubic foot ported box at 32hz sound good?
Post Number: 1701
off 1k rms the "Q" for sure
Username: Craudi0
Post Number: 21
for the 12" Fi Q, should i get a ported or sealed box?
Username: Snowball123
West Allis, WI
Post Number: 2413
well you still wanna get loud right? i'd port it.
Username: Craudi0
Post Number: 22
and would the hifonics bxi1208d for 1200rms at 1ohm be a good match for the Fi Q? and ported or sealed box?
Post Number: 1703
for better output ported for better sq sealed
Diamond Member
Www.stainles... .ecrater.com
Post Number: 20029
Higher end drivers can notoriously take more power than listed but you have to be careful in your amp settings. Just like alt applications. It's all in how smart you approach it. Sadly alot of high end sub manufacturers HAVE to underrate their drivers so the ignorant masses don't blow them up so often.
Kinda funny/ironic how lower end sub manufacturers overrate their driver's potential with disastrous results yet they still rake in the sales.
Weird.
Username: Deadrabit
Marionville, MO
Post Number: 1372
the reason i say the BL is because it has always been for me i get something with good SQ and im happy with it. being loud is something that i listen to and over a week or so it just doesn't seem as loud. it gets old so i want something bigger... maybe its because m hearing is leaving me. idk. but i think after a few months ull want something louder, but that is just what i do.
Username: Craudi0
Post Number: 28
so would 2 12" CV wmax subs be louder than one Fi SSD?
