12" Fi Q
Username: Craudi0
Post Number: 23
would 900rms be underpowering it? i have a kicker zx750.1 that i would like to keep if possible. the birth sheet said 900rms at 2ohms. would i be ok?
Diamond Member
Www.stainles... .ecrater.com
Post Number: 20028
You'll be fine.
Username: Craudi0
Post Number: 25
so would it be a waste to get an amp that puts out like 1100rms?
Username: Snarl2004
Digital Design 9515, Massive Audi...
Post Number: 2530
yes not much of a noticable difference between 200rms.
the Q will do very nice on 900rms
Username: Surferdude9371
Get loud or go home....
Post Number: 1712
not a waste at all but 900 will be fine it will just come alive better with a lil more power
Username: Loudon
Post Number: 2894
wont hear an audible difference in the woofer whatsoever
Username: Craudi0
Post Number: 26
ok thanks, and do you know anything about the newer cerwin vega vmax 122's? they handle 500 rms each, and i was thinkin of getting 2. Opinions?
Diamond Member
Post Number: 20030
Remember the old rule of doubling the power to gain 3dbs? What's 200w gonna do?
Username: Loudon
Post Number: 2895
back when i was in high school about 9 years ago they made a decent woofer .. cerwin vega has been around along time ... im sure they make a good woofer now also ... try em out and give a review
Diamond Member
Post Number: 20032
CV was a HUGE player when I was younger. (20 years ago). I mean if you had a high end system it HAD to have CV speaks. I believe comparable to today's higher standards. Not sure though.
