Will my subs blow
justinb
if you have 400 watt subs and 500 watt amp how much off a problem will that be ( if the amp is not set right will it blow the subs)
what is the rms
justin
the amp is 150 the subs dont say just max which is 400
tifish
if you have 1 sub, and you bridge it, i think it will blow. but if you have two...then as far as i know, they shouldn't, because each sub will be given 250 watts.
motoman22
clean power doesn't blow woofers, distortion and bad installs do.
