Which of These Subs is Best 4 SPL?
Username: Boston_spl
Highland, CA United States
Post Number: 101
I'm looking for 2 subs for a 2001 GMC Yukon XL. I want an SPL setup with fairly decent SQ, but not quite SQL. So like, 80% SPL & 20% SQ or so. I'd prefer not to go above 15". I also want to buy from an authorized dealer, as these two places are. I realize one sub is 1.5" smaller than the other, but it's also $400 more so I would hope that the engineering & quality make up for the small cone area difference.
So, which one do you guys think is a better quality sub, better for SPL, and which one is the best bang-for-the-buck?
Sub #1) http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4925
Sub #2) http://www.crutchfield.com/S-KCyzBKl8ZUE/p_13613W7D15/JL-Audio-13W7-D1-5.html?sh owAll=Y&tp=111
Username: Surferdude9371
Get loud or go home....
Post Number: 1588
sounds like the BL would be a perfect fit for you ficaraudio.com
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 6101
Did you seriously just compare an MT to a JL W7?! LMFAO
If you have money go with the MTs.. that is if you can drop another 3-4k on amps and electrical upgrades...
Post Number: 102
No, I didn't compare the two. I asked you guys to. And actually, I contrasted the two.
I'll look into the Fi BL P.rick. Thanks.
Username: Kingandsons07
TEAM REVOLUTION Lincoln,NE
Post Number: 449
how much you wantin to spend?
Username: Glasswolf
Raccoon City, MI USA
Post Number: 12247
the W7 is really more of a high excursion SQ sub, like the Fi Q or RE XXX.
Username: Frkkevin
Post Number: 6107
so to answer the question, MT.. or a similar sub
But again, do you honestly have the money to run such two subs as they should be ran and not blow something up in the mean time
Post Number: 451
wow lol
Post Number: 103
Oh, ok, I see. So a W7 will have similar excursion and SQ as a new RE XXX. Where as the RE MT is more of a straight SPL sub. Gotcha.
Username: Frkkevin
Post Number: 6110
the new XXX is more spl than sq vs the older version of it
Post Number: 105
That should be obvious just buy looking at it.
Username: Tejcurrent
Post Number: 1647
How much power will you be running daily? How much for burps? What frequency do you plan on tuning to?
The MT is going to be the way to go out of those two.
Post Number: 106
I actually won't be burping, but I'm looking to run about 4kw daily. I was thinking of tuning to maybe like mid to high 30's, like 36-37ish, remember I'm not burping so that's why I'm tuning low.
I'm also thinking of getting a 300A Iraggi alt. and a couple Powermaster XS D3100's.
Post Number: 1649
Don't go Irragi dude. I bought 3 380s from him and sold them to go with a 250 from Mechman. The Mechman is better ;)
I would get 2 Fi BLs (or the MTs) or BTLs. I've run 2000+ to a BL and it handle it fine, but the BTL/MT would give you room to upgrade in the future. Just a matter of price and your experience/comfortability imo.
I love my D3100s though, 2 of those batts should be plenty for 4kw with a good alt or two.
Username: Wickedbass
Nashville, Tn
Post Number: 284
"Don't go Irragi dude."
^^^Agreed. I've only had mine for a few months and am already starting to have problems with it.
I also agree with all the recommendations that have been given as far as subs. And just to reiterate what has already been said, a spl sub the w7 is NOT, trust me.
Username: Glasswolf
Post Number: 12255
actually I was referring to the first generation RE XXX in my previous post.
I ran two of them in an aperiodic enclosure with 1500WRMS each.
They did nicely for SQ.
Username: Frkkevin
Post Number: 6131
^^ .. love my 04/05 XXXs.. now if only I can find a use for them besides them sitting in a closet lol
