2001 Dodge Ram stereo problems
Username: Fran_meyer
Hi, I recently bought a 2001 Dodge Ram 1500. When I purchased it the radio did not work. I found it to be unplugged. Once I got it plugged in it has power and it works. The problem is that there is very little volume. When turned all the way up, you can hear it, but very quiet. It is a factory stereo with Cassette and CD. Any ideas what may be the problem? Any help will be greatly appreciated.
Thank you.
Username: Kcmoguy26
Sounds like it needs replaced. Go to www.car-audio-direct.com and email the guys there they are nice and will reccomend a solution
