Us amps AX-3200DE
Username: Harrymacpot
ok, well do you believe the rockford fosgate t30001bd would be a better choice, compared to the ax3200de.
or you can give some other suggestions .
im looking for a good solid 3000wrms @ 1 ohm
Username: Mixmastaspig
Team RD, Canada
Post Number: 1908
RD 3250.1
http://www.rdaudio.net/rd3250/rd3250.htm
Very solid amps.
I'm not sure on the other two as I have never used them so I don't know what they cost or how efficient they are.
I do; however, run an RD amp and it is a beast.
For pricing and all that contact Kevin @ lowhz01@yahoo.com I've bought many a things from him.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5523
put american bass on your wishlist
Username: 420alldaylong
Post Number: 3829
http://audioforum.termpro.com/topic/20/13407.html
Username: Pbplayer05
Carroll, Iowa
Post Number: 722
well the ax would be better but it will cost and arm abd a keg its a tube amp made in the us
Post Number: 3832
http://www.caraudiodeals.com/us-amps-ax3200de-p-1601.html
