Reversed Subwoofers
Username: Alpinepower
Post Number: 41
What does screwing the woofer onto the front of the box backwards so you can see the magnet and basket have anything to do with the sound?
Username: Jonathan_f
GA USA
Post Number: 278
It doesn't change the sound, it just removes the displacement of the woofer from the box. You need to reverse polarity to keep it exactly the same as it was. If your sub has a .1 displacement, then when you invert it, you effectively add .1 cu ft displacement to the boxe's internal volume.
