Jensen VM9512, To but or not to buy.
Username: Cozce
Post Number: 40
To buy* or not to buy.
I've been thinking about buying this DVD Player. It seems to have everything I want, in which it has 4 preamp volts. I would just like some feedback and/or recommendations.
onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=18602
This link shows the whole package.
eBay Link
Username: Surferdude9371
Im BTL Bumpin
Post Number: 1069
deff not worst thing i ever bought whats ur budget?
Username: Cozce
Post Number: 41
I don't plan on buying it until after I get a new car. But I'm def. willing to save up for it.
Username: Safe_cracker
Chicago, IL US
Post Number: 4660
If people are gonna start buying sh!t brands your gonna have to hang out at CA.com. Lot of mainstream crap being meantioned lately here... Polo.
Username: Cozce
Post Number: 42
Guess you didn't see the "and/or recommendations. " text in my post.
1-din dvd player motorized 7in, has usb and ipod support. Atleast 3 preamp volts. Under $1000.
SO POLO, RECOMMENDATIONS? ANY?
Username: Nd4spd18
Northwest PA
Post Number: 7857
All you need to know is that it's a Jensen..... don't touch it with a 10ft pole.
Im BTL Bumpin
Post Number: 1070
id do either an alpine or kenwood pioneer is good but they have been having issues with their rca's going bad
Username: Qslimms
Swanton, Oh Usa
Post Number: 159
i had a pioneer with navagation and stuff and i hated it cuz u couldnt watch dvds or anything except the directions while the car was in drive
Im BTL Bumpin
Post Number: 1071
you have to get a bypass for that or know which wires to twist together
Username: Visitor
Middleofnowhere, Minnesota USA
Post Number: 187
i had one. it sucked. boutght it for use in my pure spl tahoe.. didnt skip, BUT got hot, and took up to 3 min to read a cd.. normal store bought cd. a few times it simply wouldnt. the pic. quality was amazing, though. it is an audiovox unit. and believe it or not, they make some of the best lcd's for car use
Username: Spivey17323
Dunellen, New jersey 15 inch Alph...
Post Number: 1577
i bought that same one recently. it was horrible. do not buy it. it skipped my cd's like no other, cd's i had just made, and sq was BAD. buy a used older alpine or pioneer for 350-450 and you will be happy. thats what i did :-) got my new alpine for 365. look around the classifieds section over there. theres a pionneer someone is selling right now for 350 in perfect shape...
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 1916
"1-din dvd player motorized 7in, has usb and ipod support. Atleast 3 preamp volts. Under $1000."
Oh, you missed a feature:
Known to stop working after very little use.
Get a pioneer or alpine. Or if you are on a budget, go with a clarion :-)
Username: Nd4spd18
Northwest PA
Post Number: 7863
Alpine and clarion are good stuff. Pioneer used to be good but the newer ones are prone to RCA problems.
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 6058
you may think there is no difference between a nicer unit with the same specs, but you would be incredibly wrong. my kenwood unit is heed over heels better than my panasonic.
Username: Cozce
Post Number: 43
Thanks guys. This is really helpful.
Username: Cozce
Post Number: 44
How about this? A Clarion VRX585USB.
onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19536
Username: Nd4spd18
Northwest PA
Post Number: 7868
While I haven't used that particulat unit, clarion in general is good. They're not Alpine though, but I wouldn't think twice about getting one.
Username: Hittin1
Lake Charles, La. United States
Post Number: 577
only downside to that unit that i noticed was the 2v preouts..
Username: Tatonka
Post Number: 1919
"Alpine and clarion are good stuff. Pioneer used to be good but the newer ones are prone to RCA problems."
The majority of the RCA problems I have seen are from user error.
"only downside to that unit that i noticed was the 2v preouts.."
What is wrong with 2v preouts?
Username: Cozce
Post Number: 45
I def. think this is the one.
Pioneer AVH-P5000DVD
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19542
http://cgi.ebay.com/NEW-PIONEER-AVH-P5000DVD-7-MONITOR-CAR-DVD-CD-RECEIVER_W0QQi temZ160255204830QQihZ006QQcategoryZ32825QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Visitor
Post Number: 205
"What is wrong with 2v preouts?"
absolutly nothing. its something noobs worry about. the varying preout voltage is the sole reason that gain's are put on amps. set your gain correctly, and its really not a problem. if you are that worried about it, there are several nice line driver units out there. also- not all "4v" or whatever volt rca's are created equal. it is important to know at what ohm that was measured...
Username: Prozack52
Cincinnati, 2-audio puls...
Post Number: 416
ive got an alpine flip out if you can save up alpine ftw
Username: Tatonka
Post Number: 1930
"absolutly nothing. its something noobs worry about. the varying preout voltage is the sole reason that gain's are put on amps. set your gain correctly, and its really not a problem. if you are that worried about it, there are several nice line driver units out there. also- not all "4v" or whatever volt rca's are created equal. it is important to know at what ohm that was measured..."
Exactly visitor.
Also alot of higher end amps do not like high preout voltage ;)
