Fi BL stuff
Username: Deadrabit
Post Number: 522
can some one tell me what i should get on my BL? i don't want to get something if i wont be able to tell a difference.
i am getting 2 of them powered by an aq 2200
Ohm: dual 1 dual 2
P Chamfer: no yes +$10
Cooling: no yes +$40
Flatwind: no yes +$20
Daily or SPL: Daily SPL
Extreme Lead: no yes +$5
Universal
i want dual 2 ohms i think
but the extreme lead and flatwind i have no idea what that is.
i think they are all universal.
the p champer and cooling i am guessing keeps it from getting hot but is it worth 40 bucks if i am using that amp? will it be alright if i just get it with out any upgrades? i mean for 20 or 30 bucks sure but i don't want to spend 150 extra on these 2 subs if i wont be able to tell a difference
Username: Deadrabit
Post Number: 523
and what is the spl or daily?
Username: Bernymac
Cambodia
Post Number: 4086
P Chamber and cooling - for cooling purposes
Flatwind - helps handling the power better I believe
Pick Daily, no to extreme lead, maybe on universal.
Pick universal if you think you might want to recone them from d2 to d1 or d1 to d2. So thats up to you.
For better detail go here
http://www.soundsolutionsaudio.com/forum/index.php?showtopic=7154
Username: Deadrabit
Post Number: 524
so the flatwind will be good to have? and p chamber is good too.
they said they are all universal now
y no to extreme lead?
Username: Bernymac
Cambodia
Post Number: 4088
common man, read the website!
"Extreme Lead: ONLY choose this option if you plan to use the woofer for SPL ONLY applications. This option tends to yield really bad tinsel slap and rubs holes in the spiders (especially on the 10's and 12's) it is not intended on using in a daily driving scenario."
Username: Deadrabit
Post Number: 525
i just looked at that link! thanks so much!
Username: Explictx
Glen Burnie, Maryland USA
Post Number: 645
if your wiring the subs to 1ohm get dual 1 ohm coils.
Username: Deadrabit
Post Number: 540
hold up!
i am sure this is an other noob ?.
but y 1ohm dual coils not 2ohm coils?
Username: Bernymac
Cambodia
Post Number: 4092
Dual 1 VC so you can wire them to 1ohm Series & Parallel. If you do Dual 2VC you can only wire them at 2, .5, and 8.
Username: Kingandsons07
Lincoln, NE TEAM RD U.S.A
Post Number: 1056
its be cuz u have two subs if you were only doin one sub and u wanted 1ohm u would want 2DVC. if that amp can handle .5ohm and ur alt can handle it go with two 2DVC. but if you new to this just make it easy and get 2 1DVC sub's and it will run at a 1ohm
helpful link
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qt y=4&woofer_imp=3
Username: Deadrabit
Post Number: 542
do u think the aq2200 can handle .5 ohms?
ill email them and ask
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 1904
"do u think the aq2200 can handle .5 ohms?"
No, it can not. DJ has been asked that question several times lol. Just run it at 1 ohm and you will be fine.
Username: Deadrabit
Post Number: 543
ok thanks nick!
i looked at the specs and it says that the sensitivity of the hdc315s are 91.532 dB and the hdc18s are only 89.8 dB.
does this mean that the 15 inch hdcs are louder than the 18 inch hdcs?
Username: Deadrabit
Post Number: 544
ok i got kinda mixed up... i was talking aobut the audioque HDCs... looking at those too ... but maybe u know
Username: Snowball123
West Allis, WI United States
Post Number: 922
hahahaha wow. Are you ever going to buy the subs or just ask 50 questions a day on the same stuff.
Post Number: 1058
sorry to get things mix up but yea 1ohm
Username: Deadrabit
Post Number: 548
u have to know me... i can't buy something unless i know its the best for my money. when i go out and eat i talk to the workers and try to get better deals on food... my woman hates it. haha. i posted on an other thread about the hdc3 and bl... hope i can make up my mind soon!
