Components
Username: 71_chevelle
Post Number: 27
I was wondering if someone could give me advice one good component speakers. i'm thinking about putting 5.25" infinity perfect component speakers that RMS at 100 watts. and i'm considering getting a 6X9 adapter and putting 6.5" components in since that seems to be what everyone says. what would be good components to get? i havent bought any of them yet. and i need a small component like 5.25" for the front.
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 2739
How much money do you have for the speakers and an amp?
Noone can help until you give us price guidelines.
Post Number: 33
well i've already got the amp. its a 6 ch Zapco 650.6 AG series. and as the for the components i'm willing to spend around 300-400 for a really good pair!
Username: Drant19
DUB-C, TX
Post Number: 982
u can definately get better than the infinitys with that kind of budget
Username: Snowball123
West Allis, WI United States
Post Number: 702
true that. i love my diamond audio hex's.
Post Number: 42
what model of 5.25" component speakers do you suggest then Abarca?
and i'm willing to spend around $200 for the 5.25" components and around $300 possibly $400 depending on the quality of the speaker for a pair of 6.5" components
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 5165
are the 6.5s going to be for rear fill? if so don't spend too much on them, you want a stronger front stage
you could get two sets of JBL C608GTi MkII .. 5.25s and 6.5s .. on ebay they are in your price range
if you want some very natural sound thats not too bright look into DLS Audio :-)
Post Number: 46
Sweet thank you! i'll look into them!
