Bass Advice - inverted, ported, sealed???!?
Im looking for serious advice. Im trying to install some kind of sub system to a BMW e36 (sealed boot) and need guidance on which type of bass system would give the best results. 2 x 12"? 1 x 15"? Sealed, ported or inverted?? I listen to mainly bass heavy dance music and R&B. Please help!
Username: Its_bacon12
Post Number: 633
inverted isnt a kind of box or setup really, its just how you mount the sub
since you listen to bass heavy dance music/R&B, id reccomend two 15's ported
2 adire audio tempests in a 3.5 cF ported box tuned to 32 Hz would be great
Username: Pat_l
Tucson, AZ USA
Post Number: 195
Yeah, Two 15's ported
